Terra TXP-720
Terra TXP-720
Does anyone have an old Terra hand held transceiver TXP 720? I'm trying to determine the original chemistry of the batteries and the voltage output of the AC adapter. I keep downloading "the manual" and ending up with the installation manual for a panel mount TX 720 instead.
TIA
Re: Terra TXP-720
Post by 6277 »
There's one at the museum where I volunteer. www.yankeeairmuseum.org Next time I'm there I'll take a look. I'll be going there next Wed the 11th.
Re: Terra TXP-720
Thanks! If you could get the data, and a pic, of the charger that would be awesome! (I have box of adapters, but don't know if the right one is in there.) I don't suppose you have the manual, do you?
Re: Terra TXP-720
Post by 6277 »
Not sure about the charger or the manual. Will check.
Re: Terra TXP-720
I found a manual. Thanks! FYI, the original batteries were NiCads.
Still looking for specifics on the charger, though, particularly Voltage and current output.
Re: Terra TXP-720
Post by 6277 »
I have the radio and couldn't find the charger or the manual. If you want the radio, I will mail it to you in return for a donation to the museum in the amount you think the radio is worth plus shipping cost. I will send a pic of the radio if you want. 734 645-3187 cell.
Re: Terra TXP-720
Generous offer, but, then, I'd have two radios and no charger!
Aircraft Type: C140A
Re: Terra TXP-720
Post by 8474 »
Hi John,
extrapolating from this thread it looks like 12 volts is the answer....
http://www.aviationbanter.com/showthrea ... 8f&t=77305
Re: Terra TXP-720
Post by 6277 »
The radio is available to anyone on this site. Shipping plus a donation in whatever you think is appropriate. Cell 734 645-3187.
