Wheel Pant, axle bolt length
Re: Wheel Pant, axle bolt length
7698 wrote: ↑Thu Apr 23, 2020 10:40 amI'll opt for -30 on the basis of better to be looking at it than for it. :)
Make sure you have enough washers! (tradition says more than 3 and you should use a shorter bolt...) The best washers to use are MS20002-4 washers, which match the strength of the bolt and nut. Don't put washers under the bolt head; the gear leg is chamfered to match the radius between the bolt head and shank. Regular washers are not. If you insist, MS20002-C4 washers are chamfered.
Maybe the best thing to do is measure what you have, or get both.
7698
Aircraft Type: C120 - GAKVM
Post by 7698 »
6643 wrote: ↑Fri Apr 24, 2020 8:54 am
Ive measured today and if I add in the thickness of the wheel pant back plate, the grip length need to be 1-3/4" so not exactly sure if thats a -28 or -30?
I didnt pick up on it last time, but you mention that gear leg being chamfered; does that mean that the bolts should go through the legg end first and the nut be against the brake fixing plate? Currently the nuts are onto the gear leg.
7698
Post by 7698 »
7698 wrote: ↑Sat May 16, 2020 11:10 am
Ok, stupid question time... Does MS20004-28 mean that grip length is 28 x 1/16"... = 1-3/4" :)
8175
Name: Larry Lowenkron
Aircraft Type: Cessna 140A
Post by 8175 »
yes
7698 wrote: ↑Sat May 16, 2020 11:10 am Ive measured today and if I add in the thickness of the wheel pant back plate, the grip length need to be 1-3/4" so not exactly sure if thats a -28 or -30?
Yes, -28 is 28/16" or 1.75" not including the threaded portion.
Yes, the inside surface of the gear leg is chamfered and the bolt head should bear directly on it.
7698
Post by 7698 »
Thank you all...
-28 it is and bolts repositioned in the correct orientation when the back plate goes on.
:D
7698
Post by 7698 »
Sorry but Ive had a thought...
Whilst I measured the length of the bolt required, rather foolishly I didnt check to see what bolt dia is already fitted.
So if it turns out that they current bolts are AN5 does that mean that I replace with longer AN5 to suit or go to MS20005?
:oops:
No, the larger AN5 bolt has similar strength to the MS20004 bolt, so use them. If you have socket head bolts now they are almost certainly MS20004's. Do you recall what wrench you used on the nuts? Nuts for AN5 bolts take a 1/2" wrench.
Trivia: the original nuts look like AN365-4 nuts but they aren't (weren't). They were a 1940's off the shelf high strength nut and there is no AN/MS/NAS equivalent that I could find. The best I could find was NAS1804-4 nuts, which are the right strength, but 12 points instead of 6 flats. A 12 point socket or wrench will fit.
7698
Post by 7698 »
Thanks for all the guidance..
What would be the torque setting for the AN5 bolts?
Many thanks.
Refer to AC43.13-1B. I'd use 140 in-lb. With the AN5 bolts you can use standard MS20365 nuts.
