Stromberg Mixture Control Arm Extension
Re: Stromberg Mixture Control Arm Extension
Post by edidin »
Render and print of my interpretation of the Neil Wright mixture arm.
Does anyone know how to upload a .step file? That would allow one to machine after passing through a CAD or CAM program on a CNC mill easily. Protolabs can probably also make relatively cheaply.
Wright Mixture Extension Render,jpg.jpg (25.05 KiB) Viewed 1396 times
Wright Mixture Extension Print.pdf
(49.17 KiB) Downloaded 414 times
wingspinner
Aircraft Type: c140
Post by wingspinner »
Thanks for the 3d rendering. I’m pretty sure you can upload most any file if you change the suffix to .jpg or .zip or something else the forum accepts. Haven’t tried it here but that works on some forums. Of course, whoever downloads it will then have to rename it back to .step (in this case) once they get it on their computer.
