lower door post replacement plate
8281
Re: lower door post replacement plate
Post by 8281 »
I just doubled checked the doorpost and bulkhead part that i have dissembled
and will explain the Diagram pattern in the previous post!
That Diagram is showing Three (3) parts layered on top of one another. That explains the Horizontal lines in the diagram!
Two (2) of the smaller parts (plates) exist in your Plane Now and when You add the New longer reinforcement Part (Plate), You will need to remove one (1) of the existing parts (plate)!
And that will be the largest if the two!
So, get busy and get it done now that You might understand the Door post reinforcement Pattern posted above!
PS. The New part will need to be of the same thickness as the part removed, as the Lift Strut Fork will not fit if making the part of a thicker material!
8281
Post by 8281 »
To correct the wording in the above statement:
It should read "of" the two and not "If" the two!
chriscrewdson
Aircraft Type: Cessna 120
Post by chriscrewdson »
Yeah, the drawing I made shows a couple of the layers in that stack. There's one thicker plate on the forward side that has the countersunk holes, then the thinner plate that goes up inside the box of the door post. This drawing shows that and the original shorter version.
This drawing is based on the parts I had and my best guess of how tall the SK150-53 part is from the picture on the Textron page.
chriscrewdson
The drawing I made is already in CAD in Onshape and public, you just have to sign up for an account.
6641
Occupation-Interests: A&P IA Ret.
Post by 6641 »
The measures 18X28 inches and includes lots of detail.I don't have the ability to copy something that big.
Can't see how you are going to do a proper job without the data. Are you an A&P or working under one?
chriscrewdson
I am working with an A&P to reproduce these parts replicating what I have. From the pieces I have and the dimensions in the drawing I made, the full part is about 6 1/4" tall and 3 1/4" wide. It would be far better to go from the drawing you mentioned, but I don't have access to it.
6641
Post by 6641 »
You can have the drawing.
Send me a pm on where to send it.
Joe
chriscrewdson
I updated the OnShape document with the drawing and here's a photo:
