Winterization Kit
Re: Winterization Kit
You are right; the original covers go on the inside of the cowl. The hooks should be just long enough to clear the "grill" when the spring is completely compressed.
I think if I were making a set I'd make them flat and put them on the outside. Easier to make and less stress on the grills. But, in reality, I have just used duct tape...
Post by 8233 »
6643 wrote: Sun Dec 16, 2018 8:47 pm You are right; the original covers go on the inside of the cowl. The hooks should be just long enough to clear the "grill" when the spring is completely compressed.
Makes sense. I bought a set from Scott Dennison which uses a small plate on the outside and bolts that connect through the grill with the original style covers on the inside. They are not particularly fast to take on and off if you have an unexpected warm day for example. The spring hooks seems like they would be must faster but as you mention, perhaps not as kind to the grill.
8209
Post by 8209 »
I have seen the drawing that John posted. I was wondering if anybody had an actual picture of the winterization kit on the airplane.
Occupation-Interests: Flight paramedic
Post by 6991 »
Mine are installed. If I get out to the hangar tomorrow I will snap a couple of pictures.
Joe
Joe Belany
2470V
8209
Post by 8209 »
Thanks Joe, that would be great.
