ASI Questions...
8359
Re: ASI Questions...
Post by 8359 »
Just out of curiosity, whats the standard practice with multiple pitot instruments? Can you daisy-chain them like the static system?
I wouldn't call either one a "daisy chain," which brings to mind output of one connected to input of the next. What you need to do is split the static line so each instrument has a direct path to the static source. Likewise for the pitot line. (Probably what you meant anyhow). Neither line has (should have) any net flow, so there's no issue connecting several instruments to the same line using "T" fittings.
4390
Post by 4390 »
8359 wrote: Wed Jun 05, 2019 11:45 am Just out of curiosity, whats the standard practice with multiple pitot instruments? Can you daisy-chain them like the static system?
If you browse through FAA AC 43.13-1b there's a section that shows the pressure loss formulas when building/repairing pitot static systems.
4390
Post by 4390 »
UPDATE: I cleared the pitot and static lines a few days ago. I removed the line to the static port. Just took the plane out on a calm day. What a difference.... The ASI and the GPS speeds are nearly identical. ASI is working like it's supposed to now.
Post by 5115 »
4390 wrote: Sat Jun 08, 2019 10:31 am UPDATE: I cleared the pitot and static lines a few days ago. I removed the line to the static port. Just took the plane out on a calm day. What a difference.... The ASI and the GPS speeds are nearly identical. ASI is working like it's supposed to now.
Great, but keep i mind that you flew on a calm day and could be the reason why they almost matched. Don't take for granted that ASI and GPS will always match. There is a methodology in the member section to check your ASI using your GPS flying four different headings and doing some calculations.
Martin Tanguay
