shoulder harness
8175
Name: Larry Lowenkron
Aircraft Type: Cessna 140A
Re: shoulder harness
Post by 8175 »
Thanks Chris! Do you have a doubler or is it just reinforced with washers or...? Did you just do this with a log entry or a 337 or...?
Larry
8261
Occupation-Interests: USAF
Post by 8261 »
It was done by 337 about 30 yrs ago. I don’t believe there is a doubler...I’ll find the paperwork and send you a picture
8175
Post by 8175 »
Thanks, I really appreciate it.
Larry
llowenkron at yahoo
1307
Post by 1307 »
Having been in a crash in an older B55 Baron in August, 2012, that did not have shoulder harnesses installed, I can attest to the need for them. With a cracked and dented skull, and a broken neck from my head hitting the instrument panel, I will NEVER occupy a seat in a GA plane that does not have them installed. The Baron pilot died from severe head trauma 12 hours after the crash. My 140 has had a 5 point Hooker Harness installed for both seats, for many years. Works great. Not a fan of a single, diagonal strap without an airbag.
5765
Aircraft Type: 1948 C140/C-90
Occupation-Interests: retired
Post by 5765 »
I’m a big fan of the Hooker Harness. Secure 4-point design that will really hold you securely when needed. Not overly restrictive in flight.
1948 Cessna 140 N3693V
Serial Number 14969
Based at KCMA
