Right side brake pedals
Re: Right side brake pedals
Come on, it's not that bad! All you have to do is tape the nut to the tip of your finger. Then, you decide you need to use a different finger. then you decide it would be better to use one of the fingers on your other hand....
6643 wrote: Thu Feb 06, 2020 4:13 pm Come on, it's not that bad! All you have to do is tape the nut to the tip of your finger. Then, you decide you need to use a different finger. then you decide it would be better to use one of the fingers on your other hand....
Hmmm, I suspect you have the fingers with additional joints and "extension" mod.............(and longer arms and have the instrument panel removed.........)
