Fuel selector valve
Re: Fuel selector valve
8413 wrote: Thu Sep 10, 2026 8:19 am John...mark me down for a L,R,Both,Off for my 140A. I agree, probably a long shot, but now you only need 29!
Josh
Yeah Josh, Aerosmith wrote a song about these fuel valves, it's called "Dream On"
kaylee paige
Post by kaylee paige »
Add me to the list, I'd buy one! L, R, Off.
28 more...
Do I hear 27?
Aircraft Type: 140A/C90-14F
Post by 8413 »
6183 wrote: Thu Sep 10, 2026 8:47 am
Josh
:lol:
Realistically...
The Univair valve looks like a good solution, at least for the "L-R-Off" crowd. I can't imagine it would be a problem to get it approved in a "Both" plane. Maybe require a manual update, but no reason it won't work as expected.
6643 wrote: Fri Sep 11, 2026 8:36 am Realistically...
Agree with that John. I would think that modifying the "cone" or "spindle" that turns from a 90 degree hole pattern to that with a three hole pattern of 90 and 180 degrees to select fuel flow for L-R-Both-Off would be doable without too much of an issue. However, I'm not familiar with how the valve offered by Univair or for that matter by Spruce (both offer the same valve) looks inside.
I'm seeing a simillarity of all these valves that look like drop in replacements for our old beater Weatherhead valves. Of course legalities outweight function. They all seem to have the same footprint as the Weatherhead and are an improvement over the old brass on brass arangement.
https://www.aircraftspruce.com/catalog/ ... -29500.php
https://www.aircraftspruce.com/catalog/ ... -19178.php
https://www.aircraftspruce.com/catalog/ ... Cessna.php
And this curiousity....
Inst-PDF-Fuel_Selector_Valve_ICA.pdf
(1.01 MiB) Downloaded 15 times
Dakota Cub (see above)
https://dakotacub.com/products/fuel-val ... 8034504926
atypicalguy
Post by atypicalguy »
We ended up going with the one from mcfarlane or whatever for 686. One less thing to think about.
6183 wrote: Fri Sep 11, 2026 9:20 am I would think that modifying the "cone" or "spindle" that turns from a 90 degree hole pattern to that with a three hole pattern of 90 and 180 degrees to select fuel flow for L-R-Both-Off would be doable...
Yeah, but then you got some 'splainin to do...
