Metalized Wings and Pre Buy
- 8233
- Name: David Freeland
- Aircraft Type: 1946 C120
Re: Metalized Wings and Pre Buy
I'm going to look at a 120 today. Fingers crossed.
7916
I may have more experience with metal wings than I want to have, having searched for a good set as a result of problems with mine. I posted info re metal wing STC's a year or so ago. Basically, the problem area to look for is with the drag and anti-drag wires. If they are corroded or need replacing, you may have a problem. Mine were rusty and my IA said to replace some of them. We cut new holes just to get at the nut on the end but could not get them loose. There started my search! My wings were sTCd with a Rutello STC which did not permit the removal of the drag and anti drag wires. I have a 140 on the market which I have restored, almost every nut and bolt. Don't remember the STC but it permitted the removal of the wires and placed stiffners in the skin. No rust there. One issue you should look for relates to the number of inspection holes. If you can't get to the wires or nuts, you will eventually have problems or maybe already do.
The Elmira, NY EAA took the metal off theirs and covered them with fabric, saving them in the neighborhood of 20 lbs.
More like 80lbs.
- 8233
I never returned to this thread but I ended up buying a 120. It also has metalized wings but I did have a thorough pre-buy done and it was very clean and no corrosion anywhere. This STC was SA1-259 from Skycraft Designs in NY. The drag wires are still there and also appear to be in great shape. When I had Ken & Lorraine Morris doing some work on it last month, Ken commented that the wings were in very good shape and would not be hard to take them back to fabric, just a lot of labor (and cost). I might venture down that road one day. All things considered, I compromised on the metal wings since the rest of the airplane was is such good shape for the price plus it had a low time C-90 on it, 1600TT airframe and no tell tale signs of previous damage.
In the mean time, I'm focused on other smaller projects to reduce weight: Odyssey battery, alternator conversion, light weight starter. Will be making my first trek this year to Oshkosh. My first year to fly myself. Looking forward to meeting everyone there!
7916
Rutello is the STC that has stiffners on the skin and allows for the removal of the drag and anti-drag wires.
8175
- Name: Larry Lowenkron
- Aircraft Type: Cessna 140A
My IA asked me to check on an STC for a 140 he just got in and has not seen before. He is trying to do a conformity inspection on it so he can complete an annual.
It has the Skyview metal wing STC. There is a 337 from 1956, but all it says is:
"Metal wing conversion as per Skycraft Design Associates Drawing #" . No number after the "#". The only other thing is a revised weight and CG. He cannot tell if the work was done IAW the STC.
We both agreed that the plane has held together all this time(!) but he feels that it is still his responsibility to verify conformance, since it will be his name/number (and livelihood !) in the logs. I can't disagree!
Does anyone have any more information on that STC? Drawing/data be a big help.
Thanks!
Larry
Thanks!
Larry
- 5099
- Name: Ramp Rat
- Occupation-Interests: Semi-Retired A&P
Is there a Data Plate anywhere on the under surface of the wing? For example: Ruleto does not show a existing STC but their work is noted in the C-120/130 TCDS as an option. I didn't see anything for your wings but look at the 337 and see if they reference a kit number or something that might be linked to one shown in the TCDS.
JMHO, Steve
JMHO, Steve
America, Love it or Leave IT!
If the 337 refers to a STC (SA1-259) the you will not find it listed on the Aircraft Specification. The items listed there with an asterisk are similar to STC's but actually were incorporated into the approved design. Installation of one of those items is actually a minor modification...
Someone from our Association obtained the Skycraft STC for a wing leading edge landing light. (The info is secreted in the old forum...) Maybe he knows how you can contact them. Otherwise, "previously installed by parties unknown..."
(I think I found the landing light STC. Try Woodstock Aircraft Services Inc. PO Box 2, White Lake NY 12786)
