The window will go up to the wing and stay there until landing.
We used to open it while doing aerial photograph so we could get a better picture by not shooting thru the window.
Spent hours with it open with no ill effects.
Window latches
- Name: Rick F
- Aircraft Type: C-140 (sold)
- Name: Michael Haas
- Aircraft Type: Cessna 120
Re: Window latches
Thanks for the info. I'll give it a try when the hot weather returns.
Michael Haas
'46 120 - N76219
Home Base: W96 (Quinton, VA)
'46 120 - N76219
- 8230
- Name: Dale
- Occupation-Interests: Pilot
Re: Window latches
I can verify it rises and just hangs under the wing... We used to do that when in flower bombing contests..
8359
- Name: Tamer A
Re: Window latches
I flew with the window open tonight, it was awesome. Surprisingly not as windy as I expected.
8359
- Name: Tamer A
Re: Window latches
Also, to add to this discussion, my windows have VW bus latches, they work great. They don't prop the window, but as discussed the wind holds it up.
VW Bug Bus Right Vent Wing Window Latch Lock 113837640a - eBay Cheap too.
Re: Window latches
How did you attach it to the glass?8359 wrote: ↑Fri May 03, 2019 1:56 am Also, to add to this discussion, my windows have VW bus latches, they work great. They don't prop the window, but as discussed the wind holds it up.
- 5115
- Name: Martin Tanguay
Re: Window latches
I have the same, they are great.
If you look carefully at the picture, you will see the main bracket is U shaped and it is as thick as the thickness of the window frame and you rivet it to the frame. Easy, not original like the real Cessna latch, but I like to see the window wide open with the elbow outside.
Great picture.
Great picture.
Martin Tanguay
8359
- Name: Tamer A
Re: Window latches
As described by Martin above, but I'll get you some more detailed photos this weekend.
8424
- Name: Steve A H
- Aircraft Type: 1950 C140A
Re: Window latches
Is a 337 necessary to use the VW latch?
Thanks.
Steve
Thanks.
Steve
Re: Window latches
Ahh, okay. Thanks for pointing that out, I can see that it's attached to the frame. As Steve asked did you cover the installation with a 337?
