8.50 tire install 337
Moderators: 6643, 6183, V529
8359
Re: 8.50 tire install 337
Post by 8359 »
6643 wrote: Wed Feb 27, 2019 7:53 pm
8359 wrote: Wed Feb 27, 2019 1:49 pmI feel like a 1 stop STC for the 850s and Grove axles would be a big benefit to the community.
It wouldn't be much (if any) more work to get two separate STC's, which I would recommend. No reason to require one for the other. There'd be plenty of people interested in the Grove axles who would never need (or want) the big tires, and vice versa.
Anyone interested in doing this with me?
If I were younger... ;)
If you change your mind, let me know!
I guess that makes sense. Although the axles were recommended to me as a prerequisite to the bigger tires as the stock axles have been known to break?
8149
Aircraft Type: C-140A
Occupation-Interests: United Airlines 757/767
Post by 8149 »
5422 wrote: Sat Aug 25, 2018 2:52 pm The tires require “heavy duty brakes” the FAA definition in one of their mx publications was the ability to hold the brakes at full power static runup and keep tires locked. Those single puck brakes are more than enough. 1/8 inch spacers to move out brake disk were required though to keep brake assembly from rubbing on tire at low pressures. Those tires provide quite a bit of shock absorption. When I had the gear straightened and inspected I had them bend the gear an hair more in so at gross weight the tires would not splay out. There was more than enough edge distance around the original axle bolt holes to enlarge them so a 180/185 steel axle could be used.
What spacers did you use on your wheels to help the tires stop rubbing? Did you make them?
Adam Ogilvie
C-140A 1950
beaverbill
Post by beaverbill »
I believe that the wheel spacers are available from fadodge.com. They refer to them as "Cleveland Wheel and Brake Disc Spacers".
5422
Aircraft Type: C-140, PA-18
Post by 5422 »
Correct, it’s the Cleveland wheel and brake disk spacers. Like mentioned above Atlee Dodge sells them and I believe I bought mine from Airframes, inc.
tfisher1112
Post by tfisher1112 »
Could anyone send me their approved paperwork that we could submit with our field approval
Email is tfisher1112@yahoo.com
Who is online
Users browsing this forum: Bing [Bot] and 11 guests
