I recently moved a C180 into a class D airport, under a class B shelf, and within the mode C ring. It had a transponder that condition was unknown and no ADS-B. I called the local FSDO and the first thing he did was thank me for being proactive about it. The FSDO was ok with the plan of using the ADAPT ADS-B tool and also suggested I call the tower. The tower was also completely understanding of the situation and asked that I call (phone) into the tower prior to the inbound flight and once in-air with the standard announcement + announcing “negative transponder”.
Check the regulations and have your plan figured out prior to calling FSDO and tower. It worked well in my case.
Good luck and hope to see you at the convention.
2021 Convention
8313
- Name: Eric O
- Aircraft Type: C120 / C180
- Occupation-Interests: A&P IA
- Name: Jeff T
- Aircraft Type: 48 140 C90
Re: 2021 Convention
Thank You for that post . I have talked to NON adsb pilots that have confirmed that phone call works at least for now.
- VIP620
- Name: ken tengesdal
- Aircraft Type: 120
Re: 2021 Convention
not sure if this will work, those that are equipped (adsb out), one could fly to a airport out of the mode c ring, land and those that aren't equipped, set up a formation flight of 1-2 and follow the plane that is equipped into the convention
- 6898
- Name: Jeff T
Re: 2021 Convention
Getting ready to head out to 2021 KFFC for convention. Looks like the big WX has moved through and will be good to head out? safe travels
Re: 2021 Convention
Heading out tomorrow.
