Big RPM drop with carb heat
mcidoug
Post by mcidoug »
At least the troubleshooting was straight forward. Time to replace the exhaust system...
Re: Big RPM drop with carb heat
Isn't the what the make duct tape for?? :shock:
Time for the 150 exhaust upgrade!
Member's 150 Exhaust STC
No, Rick -you get the big kit of JB Weld. :)
8474
Aircraft Type: C140A
Post by 8474 »
6643 wrote: Sat Feb 29, 2020 9:40 pm Time for the 150 exhaust upgrade!
Yes, but be prepared for a long wait from Wag-Aero. I ordered in November and still waiting....
8424
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
Hi mcidoug.
Not sure if this helps, but found these on Ebay.
https://www.ebay.com/itm/Lot-2pc-Cessna ... SwJ4peVGZu
21 hours to bid. 0 bids. minimum bid $199.
Steve A H
8376
Post by 8376 »
FA dodge can set you up with a great set..... and if you need the 150 support bracket I might be able to set you up with a guy that can produce one.
1125
Aircraft Type: 120
Occupation-Interests: Corporate pilot
Post by 1125 »
I replaced my older 150 exhaust I purchased used in 1997 last year. Took it to Aerospace Welding in Eagan, MN for repair, they said it was toast. They put a new system together in 3 days, all components have part and serial numbers on them with the appropriate paperwork. I'm very happy with the installation and recommend them for all exhaust system needs. TO :)
8474
Post by 8474 »
I might have to look for another option as Wag just told me today that now its end of March for mine......
Name: John von Linsowe
Aircraft Type: 48 C-140
Occupation-Interests: CFI
Post by 5806 »
Your photo is a great example of why the pancake mufflers have an inspection AD on them. Now if that had been the cabin heat side.....
John
