gear extensions----cessna installed or modification???
did cessna install these at the factory or were they modified after some nose over events
- Name: Jeff T
- Aircraft Type: 48 140 C90
Re: gear extensions----cessna installed or modification???
They are in the parts catalog with a Cessna part number so I would think there Cessna.
They are listed as "optional". Don't know if you could order a plane with them installed from the factory, or not.
