Screw size
monceaviation
Aircraft Type: 1946 140
Occupation-Interests: AP IA
Screw size
Post by monceaviation »
Looking for the screw P/N that goes through the fuselage and holds the pulley brackets. I know the IPC calls for a NAS222-9. There has to be a alternate screw that is more common to use. any help would be appreciated.
140.1.pdf
(198.27 KiB) Downloaded 1029 times
140.pdf
(139.33 KiB) Downloaded 389 times
8175
Name: Larry Lowenkron
Aircraft Type: Cessna 140A
Re: Screw size
Post by 8175 »
I believe that is "now" an MS27039-4 Phillips Drive Pan Head Structural Screw.
Larry Lowenkron
