Cleaning the hangar
Aircraft Type: 120
Occupation-Interests: Pilot
Cleaning the hangar
Post by 8590 »
I finished my stroker build and have some parts from the donor engine and other misc parts
Everything is OBO
C85 crank “prop strike” flange bent but dials in limits. Selling as a core. Aircraft Specialties will give you $1000 for it as core toward stroker STC Kit. Selling for $500
C85 pistons and pins very good shape ultrasonically cleaned 220 hrs $250 for set
C85 Rods And bolts 220 hours, serviceable $200
Slick harness 220 hrs $200 for both
“SOLD” Scott 2000 tailwheel and springs with new tire and bearings and extra bearings and some spare parts works good $300
“SOLD” Complete pull starter assembly with new seal works good $200
Camshaft gear P/N 3506 for -8 -8f engines like brand new $200
Jack & Heintz AI & vertical DG both have caging and work well $100ea
2 venturi’s one large one small $50 for both
Original non recording Tach, works fine $100
Also available.
KX170b wired to indicator, using as primary radio RN works good $350 for radio, indicator, tray
“SOLD” KX145 with wired indicator works good $200 For all
KA134 audio panel works good $150
More from my Mooney panel upgrade Available now
Aerosonic encoding altimeter $250
RC Allen AI $250
Edo Aire DG $250
King KMA20 audio panel $100
PM for pictures or info
Last bumped by 8590 on Fri Apr 23, 2021 1:54 pm.
