Replacing Switches
Replacing Switches
Post by 6930 »
I have a '47 140 and need to replace my Radio and Light switches. I believe that if I take out what looks to be three nuts holding the switch bar in place (item 34-44) I can drop the assembly back far enough to get the switches out.
Does this sound about right?
Or, do I need to pull out the switch mounting brackets (34-45 & 34-46) with the four screws/nuts from the front?
Thanks in advance.
Mike
