Revisiting Seatbelt bracket 0425132
Saw this on Backcountry Pilot... https://backcountrypilot.org/community/ ... anes-24653
For those who aren't up to speed the bracket between the seats originally was aluminum and later changed to steel. Apparently there was a second failure fatality and the feds are showing a renewed interest in the part as of 12/14/2020.
Cessna_Seat_Belt_Mounting_Bracket_ACS.pdf
(103.83 KiB) Downloaded 1146 times
6930
Re: Revisiting Seatbelt bracket 0425132
Post by 6930 »
I checked and mine is steel, though it doesn’t have the relief cut shown in the SB. Assuming it is ok.
Mike
tonycondon
Post by tonycondon »
6930 wrote: ↑Thu Dec 17, 2020 4:37 am I checked and mine is steel, though it doesn’t have the relief cut shown in the SB. Assuming it is ok.
Mike
Mike,
Same for mine.
N2395N
tobyadobe
Post by tobyadobe »
Where can you buy steel seatbelt center brackets for C140s?
