Official FAA STC List
Name: Steve A H
Aircraft Type: 1950 C140A
Post by 8424 »
I'm sure many of you are aware of this information, but if not, this may be useful.
The FAA list of STC's for our planes is at this address:
https://rgl.faa.gov/Regulatory_and_Guid ... enFrameSet
On the left of the page, there is a list of ways to search for an STC.
The option "by make" goes to an alphabetical listing of aircraft manufactures. Clicking on C gets you to the page with the Cessna. There are 2 names to search..."Cessna Aircraft Company", and "Cessna Aircraft Company, The".
Common sense tells you that these 2 lists will contain the same STC's for our planes. Unfortunately, FAA (whom I worked for for 20 years) is not always overwhelmed with common sense! There are many STC's on both lists, but there are several that are not on both lists. For example, one STC I was searching for, SA3815NM for the BAS, Inc. retractable pull handle, is only on the "Cessna Aircraft Company, The" list.
A search in the "STC holder" option for BAS, Inc, also located it.
Our Association and Univair also have good STC lists, but not as comprehensive as the FAA site.
If nothing else, this is interesting reading at 2:30 am when you just can't get back to sleep!
Steve A H
Re: Official FAA STC List
Did you just volunteer to sort through everything for us? ;)
Don't forget to search under "Textron", too!
8424
Name: Steve A H
Post by 8424 »
O man, John, I forgot about Textron!
I just looked at their STC list, and it's only 1 page as opposed to the 2 pages at each of the Cessna lists! And Textron has STC's that are not on either of the other Cessna lists!
It looks like Lowe's 150 seat STC is only on the Textron list!
I may not live long enough to sort all this out!
Steve A H
Post by 8233 »
6643 wrote: Mon Jan 11, 2021 8:00 am Did you just volunteer to sort through everything for us? ;)
Brilliant!
8424
Name: Steve A H
Post by 8424 »
I'm a sucker for taking on trouble! I may try to consolidate the 3 lists and then figure how to get it in the resources section. It'll take a while tho.
Steve A H
8424 wrote: Thu Jan 14, 2021 3:59 am figure how to get it in the resources section.
We can take care of that part!
