Thingy on top of Turn and Bank
sbmackie
Post by sbmackie »
In the pic below, there is a disc screwed into the rear of the T and B (Vacuum) What is the disc for?
T and B.jpg (47.02 KiB) Viewed 2903 times
Re: Thingy on top of Turn and Bank
Post by a64pilot »
God that thing looks as old as the WWII instruments that were in mine.
My guess is that it’s a valve so that you can change the amount of airflow through the instrument. But that’s a guess.
I’ve never worked in a Vacuum T&B, does it only have one hose that goes to it? If so then could the disk hold an air filter?
Aircraft Type: 47 Cessna 140
Occupation-Interests: Retired Aerospace/Defense Engineer
Post by 8102 »
I found this image online from a 1940's manual. Looks like the "thingy" could be a filter.
Gregg
AN TURN AND BANK AIR FILTER.jpg (265.54 KiB) Viewed 2881 times
Yup!
Take the staples out and change the paper with bits cut from a coffee filter.
