oil pressure slow to rise
8466
Occupation-Interests: Retired Airline Pilot
Post by 8466 »
I have a C90 and when I start the oil pressure stays zero for about 90 seconds before rising. Once it rises it moves to the 40-45 psi and stays there throughout flight. It was cold today but I have a oil tank warmer I had all on night and the oil was warm to touch when i checked it. Is this normal? :roll:
Happy flying. :D
8474
Aircraft Type: C140A
Re: oil pressure slow to rise
Post by 8474 »
Check this thread, might be what you are seeing....
viewtopic.php?f=7&t=1269
Post by 8434 »
My C90 comes up in 10 or so seconds, usually sits at 30 during idle, goes up to 55-60 during takeoff when the engine is still 150F or so. Comes down to 45 when the engine temp is 180F-200F. I also use a oil heater but it still takes a few minutes to go from oil at 100F to normal operating temperature.
What oil are you using?
2356
Post by 2356 »
I had the same issue. Luckily for me, it was a bad gauge.
Thayne:
Does your engine have an oil filter? 90 seconds is a pretty long time. If the oil is draining out of the filter, that could be the reason; the pressure won't rise until the filter is refilled.
8466
Post by 8466 »
I flew again today and first startup oil pressure started rising in 30 seconds and it reached 30 in about 90 to 120 seconds. After 90 min flight i shut down to refuel, restarted and this time oil pressure rose within ten seconds but it snapped up to 30 psi like the gauge was sticking but worked normally during taxi to hanger. What would cause the gauge to stick? is it minor or major?
Happy flying. :D
8466 wrote: Thu Feb 04, 2021 3:51 pm it snapped up to 30 psi like the gauge was sticking but worked normally during taxi to hanger.
Why don't you think 30 is where it belonged?
Post by 6298 »
The pressure line from the engine to the gauge could be filled with gummy oil. I have disconnected it from the gauge and ran the engine for a few minutes until clear oil runs into a cup.
Post by a64pilot »
That or disconnect both ends and blow carb cleaner through it with the straw
8466
Post by 8466 »
thanks my amt agrees.
Happy flying. :D
