Originally Posted on Fri Nov 18, 2005 6:51 am
The article of how to check and set the fuel level for the Stromberg carburetors has been updated.
The tools needed are shown or described and the processes to set the level are included.
Doing it safely is important and care will reduce the likelihood of a leak.
Depending on the needle and seat you have (see the article on those items), be especially aware of the need to have a weight added to the float if the Delrin needle is used and be aware that some carburetors will have had the Delrin but do not now and the weight has not been removed.
Neal
Stromberg Fuel Level and Tools
101
- Name: Neal Wright
- stromberg_level_tools_g.pdf
- Methods and tools to adjust the fuel level in the Stromberg carburetors.
- (193.97 KiB) Downloaded 3146 times
