AD 47-50-02 Compliance
tdragger
Aircraft Type: 1946 C140
Post by tdragger »
Ive spent some time looking over the forum with comments on the bulkhead AD. Anyone have a rough idea the cost/time required to comply with the bulkhead inspection? Considering the doubler option if more economical.
Aircraft Type: 48 140 C90
Re: AD 47-50-02 Compliance
Post by 6898 »
David Lowe Airport on the web or Taildragger aviation also google it. hope you find your answer.
You may be able to see any cracks eminating from the the area of the nutplates by sticking an inspection mirror into the hole where the rudder cable comes out. Replacing the bulkhead and adding the doubler will not be easy.
PM sent
atypicalguy
Post by atypicalguy »
Where do I get the part? Do I need to fab the doubler plate up?
