Leanest cylinders for dual EGT install.
Name: Horacio Berardone
Post by 5469 »
Hello,
I will install Alcor dual EGT with new Alcor EGT probes type K, PN 86255.
Probes came packed with STC No SA 522 SW
I am aware about SB M89-18 that Supersedes M76-19 Rev. 1
My mechanic has no previous experience to select the two cylinders for the installation, as there are very few 140s here.
Thanks for experience / ideas about this subject,
Have a nice day !
Horacio Berardone Bouhébent
LV-NGL 1946 C140 SN 10.260.
Re: Leanest cylinders for dual EGT install.
Post by 6298 »
#2 is the hottest cylinder. The air flow tends to go over to #1. Not sure about the exhaust gas temperature.
5469
Post by 5469 »
Thank you, Randy !
Best regards
