Is a change from a C-85 to C-90 just a straight change, or is there more to it?
Si
Engine Swap Question
- simonlowther
- Name: Simon Lowther
- Aircraft Type: C120
Simon Lowther
Cessna 120 (11102)
Cessna 120 (11102)
Re: Engine Swap Question
It's pretty straight forward. The exact requirements are spelled out in Note 5 of aircraft specification A-768. You'll likely need to repitch your prop, unless you currently have a cruise prop.
- simonlowther
If the C-90 is a -14 or -16 the same mount will work. If it’s a C-90-14 you will need a different mount.
- Name: Edd
Randy, check your response - C-90-14 will or won't require different mount? There's always one smart XXX in the crowd!
I think that's a typo and he meant "-12 or -16."
