I understand the 0442119 rubber pad is no longer available. Looks like I'll need to make my own. Can anyone here give me the dimensions of the pad?
Thanks!
Rubber Pad for Tailwheel Spring Mounting #0442119
dtpilot
- Name: Dave T
- Aircraft Type: C120
- hotrodmac
- Name: Lance B
Re: Rubber Pad for Tailwheel Spring Mounting #0442119
Pulled my old one out of the parts box. It’s not cut square, but 1.5in by 1.5in is what they look to have been going for. It’s 3/16” thick.
‘53 C170B w/Avcon O-360
120-140 Assoc. NC Rep.
- 6898
- Name: Jeff T
- Aircraft Type: 48 140 C90
Last ones i made had web reinforced materiel in the rubber .
dtpilot
- Name: Dave T
Thank You for the replies! I'll be replacing the main TW spring, and want to freshen up the installation with new hardware and rubber pads.
Cut them from the sidewall of a tire.
