gascolator gasket
gascolator gasket
Post by a64pilot »
I have what I believe is the standard original gascolator, upside down glass bowl. Does anyone know the size and or source for a replacement rubber gasket?
Re: gascolator gasket
Post by 6298 »
I have got them from Aircraft Spruce. May have some in my stash. If I do, I’ll get the part number for you when I go back to the hangar..
I think this one is what you need, but I'm going from memory. Measure the OD of the glass and make sure the gasket is no smaller.
(Choices are 2", 2-1/8" and 2-1/4")
Post by 6298 »
The Spruce part number I have is 05-11189. It is 21/8 x 1/8 inch. GL-25-HD by brown aircraft.com on the package. I took apart my gascolater and confirmed it is the right size. Also works for the fuel gauges. The originals were cork.
Post by a64pilot »
Thanks guys, appreciate it, I’ll put it on my Spruce wish list. Current one is still serviceable but hard and beginning to crack, so I expect next time it’s removed it won’t be.
