Good afternoon all:
I am looking to see if anyone knows of a good shop(s) that clean, inspect, measure, re-shot peen, and primer Cessna spring landing gear. I have 2 sets of C-140 and a set of C-172 I'd like to get inspected. I heard there was a shop in Minnesota (I'm in Wisconsin) that does this but I haven't found any information. If you could let me know of a shop(s) that do this with name and location (phone number would be great too if you have it), I would greatly appreciate it.
Also, if anyone had this done and knows an approximate price, that would be good as well. I run a small salvage business so I have to see if it's cost effective to refurbish prior to sale or sell as is and just offer a refund if they are no good.
Email is best for replies please: smokinrivetairparts@gmail.com
Thanks in advance!
Todd Littfin
1947 C-140 NC4112N S/N 14025
SLOW restoration in process
Gear leg inspection, cleaning, priming etc.
8024
- Name: Todd
- Occupation-Interests: Aircraft Parts & Salvage, Owner Assisted Aircraft Sales, Flight Club Management.
- Name: Jody
Re: Gear leg inspection, cleaning, priming etc.
I’m not sure you would want to re-shot peen them.
It’s my understanding that 140 legs break at the hole the step bolt goes through, cracks start there and propagate.
I think if you want to really ensure good legs that maybe mag particle inspection or eddy current and polish out the holes.
However the crack growth propagation in high strength steel is very rapid, so if you found a crack I think it would be pure luck.
I assume but don’t know that they were only peened on the bottom?
15 years or so ago I just polished out my holes and coated the bolts in Par-Al -Ketone. I believe original steps were riveted on and not bolted?
On edit, we’re they originally Cad plated? I imagine they were and would re-shot peeing remove the Cad plate?
8024
- Name: Todd
Hi Jody:
Thanks for the information. Yes, I believe they are only shot-peened on the bottom. Mostly looking to just get cleaned up and primed to prevent more rust and degradation on the ones I would like to put up for sale.
I'll do some more digging to see that I can find.
Kind regards,
Todd Littfin
Kind regards,
Todd Littfin
- 8102
- Name: Gregg T
- Aircraft Type: 47 Cessna 140
- Occupation-Interests: Retired Aerospace/Defense Engineer
Attached is a excerpt from the Cessna 100 Series 1962 and Prior Maintenance Manual in regards to corrosion control on landing gear.
Gregg
Gregg
- Corrosion Control on Landing Gear.pdf
- (117.79 KiB) Downloaded 1019 times
phil123
- Aircraft Type: C140-O200
You might give these guys a try they would know the proper repair techniques. https://tlgw.aero/landing-gear-reconditioning
8024
- Name: Todd
Thanks Phil--I will do so--thanks for the lead!
Found this interesting video from our friends on the Cessna 170 Forum
https://www.youtube.com/watch?v=O8e_f6SWdcg
Thanks, Mike -- makes it plain and simple that there's no wiggle room if gear leg is "bent". Kinda related...I do recall an early SN 170 that I flew and was always impressed(6183 wrote: ↑Mon Jan 16, 2023 10:09 am Found this interesting video from our friends on the Cessna 170 Forum
Mac
The cure for the C170 duck waddle gear is to put early C180 gear on them.
Yep. I understand that the PPonk beef-up kit is a good upgrade, too. Still, it's reassuring that our old gear legs have really stood the test of time, especially when well maintained and not abused (...inadvertedly or on purpose
