Location of leveling screws/plan C120
Post by edidin »
Does anyone know where the level reference is in a C120?
2356
Re: Location of leveling screws/plan C120
Post by 2356 »
The Type Certificate Data Sheet has that info. The long splice plate on the fuselage side for longitudinal level. The landing gear box for lateral leveling.
Post by edidin »
2356 wrote: Thu Jun 30, 2022 2:23 pm The Type Certificate Data Sheet has that info. The long splice plate on the fuselage side for longitudinal level. The landing gear box for lateral leveling.
Thanks - I hadn't thought to look at the TCDS as all the other planes I've owned have had it in the POH somewhere. Appreciated.
It's always in the TCDS. The 120/140 predate POHs. (In fact, they predate TCDSs also. It was called the "Aircraft Specification" back then.)
Post by edidin »
6643 wrote: Fri Jul 01, 2022 8:00 am It's always in the TCDS. The 120/140 predate POHs. (In fact, they predate TCDSs also. It was called the "Aircraft Specification" back then.)
Always learning from this forum - thanks John. For some reason knew that all the control deflections were in the TCDS, but never thought of the leveling information.
