Stromberg Carburetor Inlet Screen
Post by 6795 »
Can someone explain the proper procedures to remove, clean, and re-install the carburetor inlet screen.
I thought this info was posted here but can't find it!
tonycondon
Re: Stromberg Carburetor Inlet Screen
Post by tonycondon »
Access to the screen is through the big brass hex nut 90 deg offset from the fuel inlet. Cut safety wire and unscrew. The screen is right there. No torque specified for reinstallation, just tight with no leak.
N2395N
6795
Post by 6795 »
Thanks Much!
There is a copper washer under the plug. It might make sense to anneal it while it is out.
