Howdy All,
I have the tail off my 140 to fix a couple of minor areas of filliform corrosion... While the tail is off I thought Id replace the rudder and elevator bearings/bushings. I found everything except the elevator bellcrank bushings, PN 0434149. Anyone know of a source... if not Ill just make them They are not in any catalogs (including Mcfarlans) which seems odd. Thanks, Jim
Elevator Bellcrank Bushings
8240
- Name: Jim B
- Occupation-Interests: Pilot, Southwest Airlines
Re: Elevator Bellcrank Bushings
While I haven't searched recently, I was unable to locate the bushings a couple of years back when we had the tail off our 140. I did recently order a pulley bushing from Air Power, Inc. @ Arlington, TX (www.airpowerinc.com), so it may be worth checking with them. Hopefully someone will wade in with another possible source. In any event, please report back if you do find -- thanks, Jim. Mac
