Lubrication - AN-0-6a as called out in the operators manual
rominoff
Aircraft Type: '47 C140; '48 NAVI
Occupation-Interests: Software & Systems Development; A&P/IA
Post by rominoff »
Is there a general consensus on what oil to use for general lubrication to replace what's called out in the operators manual: AN-0-6a General Purpose light machine oil? - perhaps LPS1 or or LPS2?
Re: Lubrication - AN-0-6a as called out in the operators manual
You're probably going to get a list of recommended products.
These work just fine.
-BOESHIELD T-9 PROTECTANT (available from Spruce and others)
-LPS #1 - light duty dry type lubricant whereas LPS #2 is heavy duty type lubricant that leaves and oily film. (Personally it's been my experience that with a heavier spray type lubricant, the area is also prone to collecting more dirt over time)
CRC556 - light duty type lubricant.
Boshield T-9.jpg (31.55 KiB) Viewed 2516 times
CRC 5.56.jpg (26.8 KiB) Viewed 2516 times
Aircraft Type: 48 140 C90
Post by 6898 »
T-9!!!!! Price is steep but used it on the power head of my boat engine ( Florida Gulf ) since new in 2001. lasted 10 -15 years longer than a non treated engine. I witnessed the proof. JEFF
Yeah! Last time I went looking for a can I found it at the marina.
(If you have a Bass Pro Shop near by, I think they carry it, too.)
Checked with Spruce and Bass Pro Shop on T-9 and LPS#1, all very close in price these days. Approximately $17-$19 per can. On a good note, one can lasts a long time.
