Pre-Buy Inspection
superpilotjustin
Pre-Buy Inspection
Post by superpilotjustin »
I’m looking for an IA who could perform a pre-buy inspection on a C-120 outside Springfield, Illinois. I’m a new member and have looked at the mechanic list and most seem to be several hours away so I thought I’d ask the group for suggestions before ‘cold calling’ the list. Thx! Justin
Re: Pre-Buy Inspection
Contact Ken Morris at www.taildraggeraviation.com. He's located in Poplar Grove, IL. Ken can assist you first hand or he'll know of someone close to you.
If you don't get a response from Ken at Taildragger, chime back in here, and let us know.
superpilotjustin
I will do that. Thank you for the suggestion!
superpilotjustin
Ken and his team are swamped. Any other suggestions?
I'll contact some other folks who may be able to provide a few names of individuals near you that can help you out.
Per George Horn, whom I found to be very helpful and knowledgeable over at the Cessna 170 Association:
"Only 77 miles away at Creve Cour 1H0 we have several very knowledgeable Members listed in the Directory (and that airport is well-known for expertise on old/classics.)"
https://www.airnav.com/airport/1H0
It may turn out be a good lead to enable you to get in touch with someone who can lend you a hand. Let us know how it works out.
superpilotjustin
Awesome. I’ll give them a call, see who I can find, and report back. Thank you!
David Lowe is in Western KY. He may be an option. There is no more knowledgeable 120/140 person on the planet. Send me a PM if you don't have his contact info. He may........? be able to travel to your airplane and look it over.
superpilotjustin
I see his contact info on the mechanics list. Will give him a call and see. Thanks!!
superpilotjustin
Mr Lowe is busy too! 😫 But gave me the info for David Woosley so I’ve got one more lead…
