Wood propeller
Wood propeller
Post by 7678 »
Installed new propeller. I’m based at RNO (4400’) and wanted a climb prop. So far I like it. If anyone is considering going with wood here is my thoughts...
Pros
Cost (half the cost)
Looks
Reduction in engine vibrations
Cons
Need hanger or prop cover
No flying in rain
Extra maintenance (re torque of prop bolts required every 50 hours)
I have a serviceable McCauley CF 71-48 prop if anyone is interested.
Re: Wood propeller
Post by 5099 »
Are you from Down Under????
Your picture is upside down. :lol:
Good lookin' Prop.
Steve.
America, Love it or Leave IT!
1307
Re: Wood propeller
Post by 1307 »
Nice looking prop. As mentioned above, don't fly in the rain. Rain drops will act like bead blaster, and remove the surface coating down to bare wood. Also, get a prop cover if you tie down on the ramp. BTW, looks like your Brackett air filter assembly frame is installed upside down. Drain hole goes on the bottom. Enjoy the new prop.
Re: Wood propeller
Good catch! Actually, the filter is fine; the plane is upside down... ;)
8141
Aircraft Type: 46 C-120
Re: Wood propeller
Post by 8141 »
As far as flying in the rain, doesn't the brass on the leading edge take care of that?
I had a wood prop on an RV-6 with urethane on the leading edge and flew in rain a lot with no problem.
8305
Occupation-Interests: Aerospace Engineer, Autonomous Aircraft
Re: Wood propeller
Post by 8305 »
Must be one mean engine and prop combination. You've torque rolled while still in the hangar!
6478
Re: Wood propeller
Post by 6478 »
Hi,
I sent you a PM about your old propeller but not sure that it went through. Is it still available?
Dean DeRosia
N81L
1946 Cessna 140
Glendale, AZ KDVT
Re: Wood propeller
Nice hangar!
