140 fabric wing tip spars
air2jjs
- Name: Jim
- Occupation-Interests: Mechanic, airline pilot, aviation and community food pantry volunteer.
Hello All, I'm looking for additional technical information (if available), on the alignment of the sheetmetal tip spars on the C140 fabric wing. Data shows no twist in the wing itself, which we do have. I'm having to remove the existing tip spars and re-install. Previous ground loop, somebody replaced the fwd tip spar, but alignment is off. Are there any additional Cessna drawings available for installing the sheetmetal tip spars?
Re: 140 fabric wing tip spars
Hmmmm, hmmmm......... I was in the identical situation about 1995. As I recall the spars at the tip are straight and a straightforward riveted on replacement. Are you looking for technical data and/or the tips themselves?
air2jjs
- Name: Jim
Thanks for the info. I just wanted to confirm the tip spar(s) alignment with extruded main sections. Are they centerline or possibly at an angle? A drawing should have this info. Thanks again.
