CHT/EGT Indication setups
matthewhinmann120cm
Post by matthewhinmann120cm »
Hello all,
What is everyone using for CHT/EGT indication? I currently don’t have anything installed in the plane and would like to get some kind of EMS system to monitor EGT/CHTs. What are you all using if any?
Thanks!
Matt
rominoff
Aircraft Type: '47 C140; '48 NAVI
Occupation-Interests: Software & Systems Development; A&P/IA
Re: CHT/EGT Indication setups
Post by rominoff »
I'm like you, nothing, nada, zip on the little c85-12.
Aircraft Type: 140A/C90-14F
Post by 8413 »
I have an EGT on cylinder 1. I don't find it to be of much use. I find that leaning until it starts running rough then richen till smooth works just fine and is quicker than watching EGT numbers on a gauge. I would rather have CHT on the hottest cylinder if I wanted to monitor anything.
Josh
