battery location
- VIP620
- Name: ken tengesdal
- Aircraft Type: 120
battery location
a non-electric 120, no battery box where they are normally, i have the Odyssey battery & holder, so anyone have paper work as far as installing it under the seat or on baggage floor ( favoring left side ). just need the battery for the starter, nothing else
8281
- Name: John L
Re: battery location
Just install the battery in the original location and be done with it !
I have an original battery box and mounting bulkhead that the box mounts on if needed !
Also the master solenoid and a like new battery cable !
Thanks/ John
Thanks/ John
- VIP620
what paper work does one need to install a battery box from another 120 in the original location and using a odyssey pc 680 battery
A log book entry
Search the forum. Mine is done with a log entry referencing AC43.13-2? and the PMA (applies to other aircraft) for the battery.and using a odyssey pc 680 battery
You need to find an older version of 43.13 as the reference to wooden battery box spacers was eliminated in the latest version.
