Uavionix magnetometer install
husabeast
Post by husabeast »
Has anyone attempted to install the Uavionix magnetometer in the 140 yet?
1946 Cessna 140 N72732
Building RV-8 N360FB
Re: Uavionix magnetometer install
Post by edidin »
No, but have a G5 with GMU11 magnetometer in a 120. Magnetic survey indicated under hat shelf was fine and have had no issues over three years. Just can’t have anything ferrous or magnetic on hat shelf. Had to make standoffs to allow it to be mounted right side up.
hotrodmac
Post by hotrodmac »
@edidin, how did you do the magnetic survey? What kind of instrument is needed for that? I have some pretty nasty magnetic interference in the cockpit, I’d love to find a way to pin it down.
'46 C140
Post by edidin »
hotrodmac wrote: Tue Jun 25, 2024 9:22 pm @edidin, how did you do the magnetic survey? What kind of instrument is needed for that? I have some pretty nasty magnetic interference in the cockpit, I’d love to find a way to pin it down.
Gauss meter of some kind - I will get more details from the avionics shop later today.
Shielded power can help reduce RF.
Post by edidin »
The avionics guy used a gauss meter to survey the aircraft. So presumably any good shop could do the same.
