Engine shock mounts
7077
Engine shock mounts
140 with a C-90 I want to replace engine shock mounts not sure what is the correct mount. Been told that Lord p/nJ3608-1 is the correct ones looking for some input. Rod
Re: Engine shock mounts
Depends on the rest of the model number. If it's a C90-12 it takes the conical mounts. If it's a C90-14 then it takes the Lord mounts. If you look at the front of the mount and you see a flat washer (or two) then about 1/8" of rubber then the engine case, it's a -12. The -14 has a couple of fancy cupped washers surrounding the rubber bits. They are also much more bulky, enough so that it moves the engine 1/2" forward. The later 140A engine mount compensates for that.
The -12 parts are Continental pn 22387, 8 required.
