Crack in flap
huntair1
Crack in flap
Post by huntair1 »
Have a 3/4 “ crack in flap on cessna 140. Top of flap upper right corner and stops at a rivet. What is proper fix for this? Thanks.
Re: Crack in flap
Can you post a photo?
huntair1
Re: Crack in flap
Post by huntair1 »
I’ll try to get one tomorrow.
huntair1
Re: Crack in flap
Post by huntair1 »
On the left flap, upper right hand corner. From inside edge to a rivet. About 3/4” long.
huntair1
Re: Crack in flap
Post by huntair1 »
Can a doubler and rivets be used on small crack on cessna 140 flap?
Re: Crack in flap
Need your photo - how long has it been there? Possibly sounds like stop drill and watch.
huntair1
Re: Crack in flap
Post by huntair1 »
I’ve tried resizing my photo multiple times and I’m still getting an error saying the image is too large. Any tips?
Re: Crack in flap
Size limit is about 450kB. You can try cropping the picture first, but leave enough "context" so we can tell where on the flap the picture is.
I'm sending you a PM.
Re: Crack in flap
Here are his photos:
That's where the fitting for the torque tube attaches. Are you sure there isn't more damage underneath? I forget exactly how it all fits together, but there must be a spar in there, and a rib, too.
Re: Crack in flap
Looks like possibly someone has been there before even added another rivet. Check the same location on the other flap- probably "mirror image" configuration fabrication - post that photo if convenient.
As John C says and I vaguely remember, just extended the flap and look/picture.
Even looks like someone put a narrow coat of the famous JB Weld! :lol:
