Bowed engine mount
8037
Bowed engine mount
1946 140, Continental 85 HP. Landing incident put plane on its nose. The engine mount has two bowed tubes, bowed not bent. Anyone taken a bow out of a tube, and how did you do it?
8281
- Name: John L
Re: Bowed engine mount
YES !
With another Engine Mount !
And it would be wise to check behind the Firewall were the Engine Mount Mounted as well !
There's no distinction between a bow or a bend. They are permanently deformed. If it's not straight it needs to be replaced. To do that you really need a jig. Wag Aero used to do them, but I don't know if that part of the business is still in operation.
I agree, you need to take a close look at the stringers behind each of the mounting points on the firewall. Are there any wrinkles in the boot cowl?
