Firewall crack repair
Post by 8475 »
I noted that my firewall was cracking at the starter cable pass-through.
N76415 firewall cracks.jpg (62.52 KiB) Viewed 4936 times
8475
Re: Firewall crack repair
Post by 8475 »
I cut out the cracked section.
N76415 firewall cracks removed.jpg (66.95 KiB) Viewed 4935 times
8475
Post by 8475 »
I added a patch to cover the damaged section. Also added a couple of spherical "eyeball" fittings to support the penetrations of the other cables (mixture, throttle, oil temp, tach).
N76415 firewall patch and cable fittings.jpg (79.64 KiB) Viewed 4934 times
8475
Post by 8475 »
Here's a close-up of the spherical cable fittings These are made by DoubleTee. I had these custom drilled to support two pass-throughs each. I highly recommend these.
https://www.firewallfittings.com/product/ttp-s-custom/
N76415 firewall cable fittings.jpg (56.14 KiB) Viewed 4934 times
8475
Post by 8475 »
Here's a picture of the finished installation. Really pleased with how this turned out.
N76415 firewall cracks patched.jpg (116.55 KiB) Viewed 4934 times
Sweet!
6643 wrote: ↑Tue Sep 24, 2024 3:24 pmSweet!
Yup, I agree!
