Fuel drain valve part number
harejac
I’ve got a leaky fuel drain valve on 1946 C140, but I can’t seem to find the part number. I believe it’s a CAV-170 but I can’t confirm. Can anyone help provide confirmation on the part number?
Re: Fuel drain valve part number
Mine are CAV170 but I think if you look closely you will see a stamping on yours. IIRC there is some discussion on pipe thread and straight thread on the fuel tanks.
Additionally to what David has said, it wouldn’t be a bad idea to read through all these postings on the subject first. There are different drains that were utilized during the Cessna 120/140 production run.
Mike
https://www.cessna120140.com/Forum2018/ ... ?f=7&t=387
Mike
tonycondon
- Name: Tony
I had a dripping valve and along the way discovered that somehow i had one wing with straight threads and the other with pipe threads!
N2395N
You're not the only one.tonycondon wrote: ↑Fri May 09, 2025 11:54 am I ... discovered that somehow i had one wing with straight threads and the other with pipe threads!
I was going to suggest a swap, but one wing with a flap and one without would probably be less desirable.
