Pull Starter
tomreneau
- Name: Tom Reneau
- Aircraft Type: 1949 C140A
Pull Starter
Anyone have an extra pull starter cable with a knob and not a t handle sitting around?
- IMG_1468.jpeg (156.22 KiB) Viewed 6080 times
- IMG_1469.jpeg (162.54 KiB) Viewed 6080 times
chewie
- Name: Mark
Re: Pull Starter
Would an old mixture control work? I think I still have one in the hangar. Black knob similar to what you're showing. It was too short when I swapped out my carb.
Mark Johnson
Re: Pull Starter
You can buy a generic cable from Aircraft Spruce. If your casing is in good condition you can often just replace the core.
https://www.aircraftspruce.com/catalog/appages/a730.php
(Boy, have the prices gone up!)
End fitting:
https://www.aircraftspruce.com/catalog/ ... -16000.php
End fitting:
tomreneau
- Name: Tom Reneau
Re: Pull Starter
I discovered that the wire used in the Spruce replacement cable is larger than the original. The A730 has 050 wire and will not fit in the factory cable housing. I have McFarland working on it.
