SL 77-6
kduck
SL 77-6
Post by kduck »
Does anyone have the original sl77-6 (fuel caps)? Do not need the revised current copy. Thanks
Re: SL 77-6
I only have the revised SEB92-27 later version. What are you trying to find out? Below are some gas cap 'readings' from Neal Wright that might interest you.
https://www.cessna120140.com/Forum2018/ ... f=10&t=138
https://www.cessna120140.com/Forum2018/ ... f=10&t=106
https://www.cessna120140.com/Forum2018/ ... f=10&t=103
kduck
Re: SL 77-6
Post by kduck »
6597 wrote: Tue Jul 29, 2025 11:42 am I only have the revised SEB92-27 later version. What are you trying to find out? Below are some gas cap 'readings' from Neal Wright that might interest you.
Thank you very much for your reply, will read these.
bc12d
Re: SL 77-6
Post by bc12d »
I have found the Half vented unauthorized 140A fuel caps on my C140, not yet flown but will be replaced with the original caps. Thanks for posting the info.
Re: SL 77-6
Here's another article I found from Neal....
Gas Cap Problem Article.pdf
(87.14 KiB) Downloaded 542 times
