Searching for a starter clutch
alexallen
I am still using the Delco pull starter and am in need of a replacement clutch. Anyone have an idea where I can get one?
Re: Searching for a starter clutch
https://niagaraairparts.com/
Niagara Air Parts used to be the go to for the pull starters but they aren't advertising it anymore. Don't know if they still service them on the side or not. All I can suggest is to contact them and see.
tonycondon
- Name: Tony
my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
N2395N
Yup, this is a "tuff one". I get a couple calls a year on this issue and so far have been un-able to find a source..........tonycondon wrote: ↑Tue Oct 14, 2025 6:39 pm my understanding is Niagara is no longer making clutches. they are not servicable in the field, so as they start failing, we all will be switching to light weight starters I guess
- Name: Jeff T
- Aircraft Type: 48 140 C90
I have a couple 815 695 9970 weekdays
