lower door post replacement plate
6543
Post by 6543 »
Does anyone have a drawing for the lower door post replacement plate? The one that is used to fix the cracked lower door post.
Thanks.
8281
Re: lower door post replacement plate
Post by 8281 »
I have a Plate, but not a drawing.
chriscrewdson
Aircraft Type: Cessna 120
Post by chriscrewdson »
I made this in onshape, but I'm not sure if it matches the SK150-53 plate.
Link leads to a login page...
6543 wrote: ↑Wed Oct 15, 2025 6:03 am Does anyone have a drawing for the lower door post replacement plate? The one that is used to fix the cracked lower door post.
Thanks.
Contact David Lowe, he made up an STC with Cessna's blessing for that.
6641
Occupation-Interests: A&P IA Ret.
Post by 6641 »
Test
6641
Post by 6641 »
I have the Cessna drawing 0409012. It was given to me by another form member 19 years ago. I don't remember his name but he was a frequent poster.
My left frame had the typical crack but since the airplane was apart I did both sides. The job requires a using a pretty heavy rivet gun as some rivets are double flush.
I would appreciate it if you would pass them along to the club library when finished.
Message me where you would like them sent.
Joe
chriscrewdson
Can you post the drawings here? Here's the drawing I made using the parts I had an best guesses from the pictures at https://ww2.txtav.com/Parts/PartSearch/ ... l/SK150-53
Door Post plate-2.pdf
(20.75 KiB) Downloaded 411 times
Post by edidin »
If anyone is interested, I could make a model of this plate and then it can be made in various ways, including by sending to Send-Cut-Send which can provide 2024-T3 material in various thicknesses.
However, I don't fully understand this print - is it multi-layered? Normally would not expect to see the two horizontal dark lines. Perhaps they are bend lines?
Cessna Plate.jpg (34.67 KiB) Viewed 9866 times
8281
Post by 8281 »
I have a door post and gear box bulkhead dissembled and will explain the diagram of the reinforcement part better!
I do know that there are No bends in the new Alum. part being replaced!
What is being done here is to remove a small existing alum. Part and install a longer alum. Part
that extends up the backside of the door post!
It's simple as it gets!
Actually, what the Diagram in the previous Post is showing is layers of the parts!
