Access To Rudder Cable Pulleys Under Baggage Floor
rvaflyer
- Name: B Hebert
- Aircraft Type: C-140, COL-3
- Occupation-Interests: Retired, now flying for fun.
Any ideas on the best way to access the rudder cable pulleys under the baggage floor for replacement (other than hiring an octopus)?
Re: Access To Rudder Cable Pulleys Under Baggage Floor
Welllllll.............. when I was younger and more agile I was able to do it. As I recall, I made/modified a wrench to assist. It helps if you take what little tension is on the rudder cables off when you R&R the pulleys.
Perhaps hire someone very small..........to do the work.
Yes, the two rudder cable pulleys are at the "edge of the universe"
