I am routing a new 4GA wire (M22759/16-4-9) to the battery and I am trying to figure out how to protect the cable during its travels through the bulkheads.
Should I use something like AN931 Elastic Grommets? Or some kind of wrap?
Here's the cable going through the gearbox.
Battery cable wear protection
chriscrewdson
- Name: Chris Crewdson
- Aircraft Type: Cessna 120
Re: Battery cable wear protection
I would say yes Chris, there are supposed to be AN931 grommets in those holes. Check the 120/140 parts book in the documents section of the main web page. Figure 18 does show the AN 931-7-11 grommet used in several locations in the bulkheads. My 140A uses the same to protect the battery cable running through the bulkheads.
Mike
Mike
tonycondon
- Name: Tony
i have grommets and the cable is wrapped in a plastic sheath of some kind.
N2395N
For something like that I prefer "tracks". Or Grommet edge seal.
https://www.aircraftspruce.com/catalog/ ... kkey=21018
Basically a thin plastic serrated edge protector. Radio shops use it all the time, I feel it protects long term better than grommets. Also.......you don't need as large of a hole and usually easier to install with the wire in place.
Good point Victor, I forgot about those. It’s a shame those probably weren’t available when these aircraft were being manufactured many moons ago.V529 wrote: ↑Mon Dec 08, 2025 7:40 am For something like that I prefer "tracks". Or Grommet edge seal.
Here's a better pic of the stuff at the shop. Set of side cutters and half dollar for reference.
Personally I prefer the clear plastic as opposed to the green metal band,
The differenct is the clear plastic is easier to install.
The green metal units are "sturdier" and will hold up better for more severe conditions.
- tracks 2.jpg (81.51 KiB) Viewed 2368 times
- tracks 1.jpg (100.73 KiB) Viewed 2368 times
chriscrewdson
I ordered a 100 feet of this from Spruce, if anyone needs some short bits of it:
NATURAL SERRATED POLYETHYLENE GROMSTRIP .037 TO .071 100FT ROLL
